 Glow plugs for the 3L
zoochy
Home City : Tropical Canada
Model and year : LH107G 1991
PostSubject: Glow plugs for the 3L   Sun May 11, 2008 5:50 am
Did some searching/cross referencing over the last week and thought I'd share...
Glow plug = "Super quick type"
OEM= 19850-54090 or 19850-54010
HKT= PT-151
NGK= Y-715R
Bosch= GPT-223 or Bosch 250202006
Champion= CH154
Denso= DG-211 or 067100-1210 or 067100-1710
Volkswagon= J1985054090
Delphi= HDS262
FAI= GGP52
AJK= JAS114TO
BERU= 968MJ or GV968
Lucas= HDS234
I ended up buying a set through krazykritters in Oz because the price was good and he doesn't screw you on shipping.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=150174566272
From krazykritters you can also buy clear epoxy shifter knobs with scorpions embedded in them if you so desire...
Number of posts : 150
Home City : Lincoln England
PostSubject: Re: Glow plugs for the 3L   Sun May 11, 2008 6:44 am
Super Info!! Well Done zoochy
Number of posts : 1117
PostSubject: Re: Glow plugs for the 3L   Sun May 11, 2008 11:06 am
Good work Fella Very Happy
tamarack
Number of posts : 101
Home City : Vancouver
PostSubject: are glow plugs same on 3L as 2C    Mon Dec 08, 2014 3:41 am
are the glow plugs the same on the the 2c as the 3L?
tamarack
PostSubject: Re: Glow plugs for the 3L   Sat Dec 13, 2014 3:36 am
seems after some research most hiace engines employ 11 volt 95mm same as hilux and some landcruisers. not sure about the 2c engine found in town/liteace.
Happyjack
Home City : Corby
Model and year : 1990 pop-roof Hiace Cruising Cabin
Registration date : 2014-07-22
PostSubject: Re: Glow plugs for the 3L   Fri Jan 19, 2018 5:27 pm
Hi, Just had a bad case of poor starting in the current icy conditions. Took 3 or 4 goes of
cranking before it fired up with lots of white smoke.
Figured it was down to a glowplug being faulty.
Couldn't believe it when I checked them. The resistance should be
about 1 ohm or less.
All 4 plugs were duff!
The old glow plugs resistances measured 59 ohms, 10 megohms, 0.5 megohms and open circuit!
I'm not surprised it was struggling to start!
Anyway, the replacements I fitted to my 3L engine are
www.Blueprint-adl.com - part number ADT31807.
They look the same as the old ones and it starts fine now.
top tip, don't over tighten the plastic nuts that hold the glow plug busbar onto
the glow plugs. There is a threaded brass sleeve inside the nut which comes adrift if you
over tighten. Doh!, fitted ok but I'll struggle to get it off in future.
I reckon finger tight would be sufficient so as not to do the same.
cheers
Happyjack
(Mike)
» Chatbox name glow
» Group's style on legend: glitter, icon & glow
» Glitter,Glow style names
» How to make username glow
» Name Glow codes and where to put them.
