 Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G
Goto page : 1, 2  Next
Dwayne
Number of posts: 20
Model and year: 1995 KZH106G
Registration date: 2008-01-31
PostSubject: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Tue Jun 10, 2008 6:35 pm
This model has the ¾ passenger seat with the fold down seat back. You know the one with the sad excuse for cup holders that you keep knocking over with your elbow!
1.Lift the engine cover (passenger seat) and secure in the normal fashion using the black strap located by the passenger seat belt.
2.We need to gain access to the driver side engine cover. Using a Philips screwdriver remove the driver side wheel arch trim. On mine there are three screws, and then you need to push the trim forward to unclip it from the two locking tabs. DO NOT try and pry it directly upwards as you risk breaking these tabs.
3.Remove the driver seat. Remove the 5 x M10 bolts holding down the seat. Three of these have rubber caps on them which you may have to pry off with a screwdriver. Remove the seatbelt warning light connector which you access by sliding the seat forward. This consists of a secure latch as well as the actual electrical connector. Use a screwdriver to GENTLY slide under the secure latch to remove it. Use the same technique for the electrical connector. You can now lift the seat out of the van. The carpet can now be pulled clear although you may have to remove the hand-brake cover if the carpet is trapped under it. This is held by two screws; simply slide it off the hand-brake.
4.Remove the driver engine cover. Unbolt the 7 off M10 bolts holding down the cover. Move this off to the side so you have clear access for the radiator to come out. You should not need to remove the hand-brake cable unless you want to remove the cover from the van.
5.Drain coolant from radiator and engine block. Use the drain cock on the bottom left of the radiator and the engine drain plug on the oil cooler. (Or use what ever method suits!)
6.Remove top radiator, return and reservoir hoses. Remove the two bolts holding down the power steering reservoir and move this off to the side to allow you access to remove the radiator reservoir. Undo the 1xM6 bolt which holds the reservoir in place. The bottom of the reservoir has a support spigot which locates in the fan shroud boss. Simply lift the reservoir out to remove it.
7.Remove viscous fan and shroud. The shroud actually consists of two pieces, a main body and a top ‘strip’ which comes off allowing you to remove the fan. Remove the 1xM6 bolt which holds the top shroud ‘strip’ piece (on drivers side). Unclip the ‘strip’ and remove. Undo the 4xM8 nuts (12mm spanner) connecting the fan to the pulley. There’s not much room here and the trick is to USE THE SPARE HAND TO PUSH DOWN ON THE ALTERNATOR BELTS which stops the pulley from moving while you undo the nuts. Use this technique as well for tightening the nuts on re-assembly. The fan can now easily be removed. Next, remove the main fan shroud body via the two M6 bolts at the top two corners. The shroud has location tabs at the bottom of the radiator and the shroud can now be removed by pulling it upwards to release the tabs.
8.Remove the radiator. Now that the shroud is gone, the bottom hose can now easily be removed by removing the spring clip. Now that we have all the obstructions out of the way the radiator is relatively easy to remove. It is held in place at the top by 1xM8 nut. This is located underneath the driver side engine cover seat latch. You may have to pull the carpet out of the way to get access. The bottom of the radiator is held by 2xM8 nuts. The passenger side nut can be accessed by getting underneath the van and the driver side accessed by reaching down from the engine bay. Hopefully these aren’t too corroded as the studs are mounted on rubber blocks which don’t like being subjected to too much torque. Take care with these and a dab of anti-seize compound on reassembly means the next time they come out will be easy! Carefully remove the radiator trying not to damage the fins! Take your time on this last step as you don’t want to taint your hard work so far by further damaging the radiator!
9.Reassembly is the reverse of above but outlined below:
a.Put in radiator, bolt in place.
b.Attach bottom hose to radiator.
c.Attach main shroud to radiator.
d.Attach viscous fan 4 nuts, REMEMBER; push down on alternator belts with free hand to stop pulley rotating when tightening nuts. Pulley can be rotated with the normal belt tension to access the nuts underneath.
e.Attach top ‘strip’ shroud.
f.Attach reservoir bottle.
g.Attach top hoses.
h.Attach power steering reservoir.
i.Check everything is connected and then re-fill engine with fresh ‘long life’ coolant, 50/50 mix preferably with distilled water.
j.Run engine, check for leaks and top up coolant as necessary.
Hope this helps!
Number of posts: 857
Home City: Hervey Bay Qld
Model and year: 1994 sc
Registration date: 2008-08-15
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Sat Aug 16, 2008 2:35 am
Good post mate Very helpfull, hope I don't have to use it Smile
roygee
Number of posts: 19
Registration date: 2007-09-22
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Thu Jul 15, 2010 3:26 pm
35YRS MECHANIC
DONOT ATTEMPT THIS JOB IF YOU HAVE ANY HEALTH ISSUES, IT IS LABOUR INTENSIVE, IF YOU ARE HANDY DONT ATTEMPT IT.
L HAD RECORED THE RAD A YEAR AGO, THE CORE IS CORRODED AND IS NOW LEAKING. TOYOTA AUSTRALIA DONOT HAVE A NEW RAD FOR MY SUPER CUSTOM. A CORE WAS MATCHED AND A RECORE WAS DONE BY ODIN RADIATORS.
THE WARRANTY IS NULLIFIED BECAUSE THEY DID NOT R AND R THE RAD.
WHERE IN PERTH CAN I PURCHACE A NEW RAD .
KIND REGARDS
ROYGEE
michael c
Number of posts: 3
Home City: Wellington, NZ
Model and year: 1994 Hiace
full time 4wd
3l turbo diesel
1kz-te
Registration date: 2010-09-21
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Fri Sep 24, 2010 10:09 am
Hi Generally very good how to,
I followed it recently and it was a very good guide to helping me get my radiator out.
i have a 4wd 3l turbo model and there were a couple of extra connectors which connect the main rad. to a secondary radiator. otherwise much the same.
I thought I would comment because after I did the radiator swap out, I simply did:
within a couple of days of the rad. change I now have coolant gushing out the the overflow bottle and exhaust fumes bubbling up through coolant, which I suspect is due to a cracked head/blown head gasket.
I found out you generally should bleed the coolant system after this type of job as if you dont you can have problems like I now have.
grateful for the post, just thought mention of this might make it better!
Number of posts: 450
Home City: AUS
Model and year: 4wd sc
Registration date: 2008-06-04
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Fri Sep 24, 2010 11:43 pm
Good to know, I have to replace my radiator eventually cause i noticed a small leak in the core a while back, it's only weeping slightly but it's just a matter of time really. I'm on the hunt for a second hand rad but no luck so far.
Home City: AUS
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Fri Apr 01, 2011 4:41 am
I took mine to a radiator specialist to get an idea if it could be re-cored but it was all bad news! Mine has a small crack on the side of the tank that can't be repaired because the tanks are plastic. The guy said once they reach about 10-12 years the plastic has expired. The only option is to buy new from Japan. affraid
He told me to check the horizontal radiator for any signs of leaking as well cause it's probably in similar shape, and guess what? It is! It's leaking on one side as well! Mad
Toyota are giving me a price on Wednesday, i will make sure i'm sitting down.
snd.wave~
Number of posts: 19
Home City: Melbourne
Registration date: 2011-04-22
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Fri May 06, 2011 8:04 am
Hiya Srburnsy,
just wondering if Toyota gave you a price for a new radiator?
cheers
Ben
Home City: AUS
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Sun May 08, 2011 8:48 pm
Hi Ben, yeah i think it was around $900 each from memory. pale I have ordered both vertical and horizontal radiators so not a cheap exercise but have no other option in my case. Rolling Eyes
So Ben you need one too eh?
Home City: AUS
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Mon May 09, 2011 12:13 am
Ok so i called up Toyota to see if there was any news on availability for both radiators and yes it seems they are. Smile They gave me a quote for the radiators and the water pump.. $1600 inc tax affraid I have order them so should have them in about 4 weeks they said.
snd.wave~
Number of posts: 19
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Wed May 11, 2011 10:49 am
Hi srburnsy,
thanks for the update. This is probably a very strange angle for me to enter the forum on, as it was my first post and I don't own a a Hiace ... yet. I have been poised to make a purchase for some time now, and have been on the forums, doing the research. Any day now I will buy one from auction in Japan, and have it shipped. Before I stray further from the original topic, have to say, what a vehicle!!
Home City: AUS
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Thu May 12, 2011 6:04 am
Welcome snd.wave~, yeah they're great package ay. What model are you hunting for?
snd.wave~
Number of posts: 19
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Thu May 12, 2011 11:22 am
Pretty much looking for any of the SC's from 1996-98, the standard model, nothing too fancy. There are plenty up for auction, so can be fairly picky. Just hoping that the km's are fairly honest to the cars history. Will probably try and source some add ons like the nudge bar and side mirror. Will be used as a work vehicle, and for surf trips. Ready to put a lot of love in I love you
Home City: AUS
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Thu May 12, 2011 8:50 pm
Surf trips..... You need the 4WD then. Wink
snd.wave~
Number of posts: 19
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Thu May 12, 2011 10:25 pm
Ah yes definitely a 4WD model. Would love some of the add on trims, but its hard finding out which vans have what. I don't suppose many come up for wrecking in Oz either?
Home City: AUS
PostSubject: Re: Removing a Radiator from 1995 Hiace Custom 1KZ-TE, KZH106G   Fri May 13, 2011 1:23 am
Keep an eye on ebay and this site www.japanoid.com/index.php Email them what you want and they usually can find it second hand factory equipment.
Page 1 of 2Goto page : 1, 2  Next
» 1995 JACKSONVILLE JAGUARS UNIFORM
» Removing Ball Joints on a Polaris Sportsman
» koyorad radiator utk kancil l2 manual
» grill guard and radiator shrouds
» Custom cap weapons and armor?
