I have recently fitted a boost gauge to the ol`bus and thought id share my expedition
.This mod is fairly straight forward and probably of interest to those wishing to mod their performance or monitor a potential problem.I have also fitted a temp gauge to act as backup to the original.As i didnt want to hack the dash to bits to fit the gauges and because i didnt want to pay£30+ for a door post pod to fit them in, i mounted them here
Next step was to figure out where to run the piping to the gauge from the engine.Because my engine is the 2.4turbo this is where i had to tee into the system with the piece supplied (tee piece in white in centre of pic)
.I fed the piping over the top rad hose and loosely clipped with tie wraps and pushed the hose through the small glimmer of light in the pick below the top hose in the picture
.The pipe came out here under the drivers wheelarch
and was run behind the pipes you see.Next step was to remove the plastic wheelarch trim inside(3screws DONT PULL),and the trim needs to be pushed forward towards the front of the van to release it from a hidden clip.The carpet was rolled back and the rubber grommit(left of pic) had a cross cut into it to push the piping through.The pipe was then layed alongside where the floor slightly raises to protect it and fed round the back of the accelarator pedal
.The final step was mounting the gauges and where to feed everything.Because it was convienient i chose to feed everything through where the brake resevoir is situated and to modify the cap
.The bottom of the dash(obviously) has to be removed to gain access to the wiring and to allow easy feeding of the piping.The clocks were mounted with a combination of a thin metal bracket purchased from motorworld(£2.50 seen in pic against and going behind door post) ideal as it didnt need cutting and used existing screw below resevoir cap as the bottom mount, and a couple of small strips of sticky backed velcro(£1.99)purchased from local diy shop.To get the gauges to sit together i fitted the clasps that came with the gauges and used milliput to attach them.The earthing was connected behind the dash to a mount and the positive was connected to the yellow and black from the ignition.The gauges were purchased from local dealer(£50 when i went in£43 when i came out) but i had to purchase extra piping for it to reach the front in one go(try local aquarium shop).Some usefull info if your thinking about modding or diagnosing,the acctuator pressure set on the 2.4 engine is 7 p.s.i(i have a new one and it produces this on the gauge aswell).This, depending on age an state of the acctuator can be up or down a little bit but 7 p.s.i is a factory setting.The e.c.u actually monitors this via the boost sensor and will cut back/retard fuel e.t.c to maintain safe levels of boost.The e.c.u is set roughly to apply safety measures at about 11.5 p.s.i (13.5 was achieved on mine).While upping the boost will get you performance,it will do so at the expense of the turbo/engine so PROCEED AT YOUR OWN RISK.Levels of boost banded about around other forums reguarding tweaking this engine are between 9-10.5 p.s.i .THIS ISNT THE SAFE AMOUNT IT IS THE AMOUNT CONSIDERED TO BE ENOUGH SO AS NOT TO TRIGGER THE SAFETY SYSTEMS OF THE E.C.U.Those serious about modding boost levels would be advised to fit an intercooler first to their system as this helps reduce inlet temps and allows more fuel to be added.Hope all this blarb is of use to someone
