| | CAV Type Fuel Filter 1KZ-TE | |
| Author | Message |
mr freeze
Number of posts: 148 Home City: Sydney South Model and year: 99 SC 4WD 1KZ-TE Registration date: 2008-07-14
 | Subject: CAV Type Fuel Filter 1KZ-TE Thu Aug 14, 2008 8:52 am | |
| Has anyone ever fitted the CAV type fuel filter to a 1kz-te before, I want to fit one but the guy that sells them said not a good idea because it is an EFI engine. The CAV is 5.5 micron rating , does anyone know what the standard Toyota fuel filter micron rating is. I had a 120 series prado a few months ago that stopped on me because the fuel filter blocked up and the warning buzzer never went off , so thats why I want to fit the CAV filter to my scv so I can see any crap in the glass bowl and replacement filters are only $5 oposed to $50 from toyota By the way I sold my 2003 Prado Diesel and have upgraded to a 1998 Super custom 4X4 that would blow the pants off the Australian Prado , no comparison at all. Should have it in a couple of days , it is getting complied now. Thanks fellas !!!  |
zoochy
Number of posts: 148 Home City: Tropical Canada Model and year: LH107G 1991 Registration date: 2007-01-21
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Fri Aug 15, 2008 3:26 pm | |
| That is really odd. Did the guy mention why it was not a good idea? A filter is a filter.
I belive toyota spec is 10 micron. |
mr freeze
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Sun Aug 17, 2008 3:41 am | |
| Made a few more enquires and all the injection pump guys say the same thing, CAV is 5.5 micron and I think Toyota about 2 micron ( still can't find out exactly) They say CAV filter should not be used on any electronic fuel injecetd diesel, so I guess I'll have to stick with the expensive genuine Toyota filter Still doing more homework when I get time to see if I can get 2 micron cartrige for CAV type filter See You !!! |
zoochy
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Sun Aug 17, 2008 5:25 pm | |
| What is your filter part #? I'm curious to know if it is the same as the 3L engine. |
mr freeze
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Tue Aug 19, 2008 2:22 am | |
| Hi , sory I cant tell you as I have'nt got the van as yet , should have it towards the end of this week or next week as it is getting complied for rego. I'm just in the process of gatthering info on these filters as I want to go a different parth from when I owned the Prado 1KZ-TE that was expensive to change filters and you cant see any dirt unless you unscrew the thing which is a pain in the ********[/img] |
Abaddon
Number of posts: 41 Registration date: 2008-02-07
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Wed Aug 27, 2008 5:46 am | |
| Hey tritrade RYCO make filters for these... should be able to pick one up down at repco... if your anywhere near artarmon go there those guys are pretty good.
In the UK I use ALCO branded ones but they look like ryco... rofl they probably just renamed them in aus. |
Dwayne
Number of posts: 20 Model and year: 1995 KZH106G
Registration date: 2008-01-31
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Sat Dec 13, 2008 6:24 pm | |
| Guys, IMHO dont muck around putting in 'other' brand filters. You want to look after your baby right? Just use the genuine Toyota ones...you cant go wrong.... They may be more expensive but trust me when I say you'll feel a lot more at ease with the genuine parts in. |
want33s
Number of posts: 76 Age: 40 Home City: Sunshine Coast. Queensland Australia Model and year: LH107... 1989 4x4 Registration date: 2008-10-02
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Sat Dec 13, 2008 7:11 pm | |
| | tritrade wrote: | I had a 120 series prado a few months ago that stopped on me because the fuel filter blocked up and the warning buzzer never went off.... |
The alarm on the filter isn't for dirt..It doesn't tell you when the filter is clogged... It's a float switch that rises when water accumulates in the bottom of the filter.
Jas. |
Robbo
Number of posts: 98 Home City: Sydney, Australia. Registration date: 2008-02-16
 | Subject: Re: CAV Type Fuel Filter 1KZ-TE Mon Dec 22, 2008 12:57 pm | |
| | want33s wrote: | | tritrade wrote: | I had a 120 series prado a few months ago that stopped on me because the fuel filter blocked up and the warning buzzer never went off.... |
Jas. |
Correct. I had this warning light come on in mine (97 3.0 litre SC). There is also a drain tap in the bottom of the filter for a quick way to get rid of the warning.
I drained mine and put it back, just to get rid of the danger quickly, then checked the tank which was ok. There is a tank drain plug. I ended up getting a Ryco filter for it. They are as good as OE and in Australia, many cars have re-branded Ryco filters as OE .
I also use a Ryco filter for the oil. Just use the equivalent Prado year model with same engine to get these parts. I also use "Diesel Power" fuel additive in the tank now. It's supposed to be the best one and reputedly will absorb water so it can be consumed in the fuel charge, rather than building up in the filter and tank.. |
