Big Lloyd Been here a while
Number of posts : 103 Age : 53 Home City : East Hertfordshire UK Model and year : 1994 sc 2.4td Registration date : 2007-12-07
 | Subject: Gearbox warning light......... Mon Sep 22, 2008 9:15 pm | |
| On the way home from work today the gearbox warning light on Trundlebus came on whilst I was traveling at about 110kmh. ( 2.4 td SC auto c/w auto box) I slowed down and it stayed on. As I came off the motorway and came to a halt in traffic the light went off. The old girl pulled away ok .. 1st gear (ok) 2nd gear (ok) 3rd gear felt sluggish , almost as if ( I know it has not got one ) the clutch was playing up....... ANY IDEAS?  |
jimsmim Been here a while
Number of posts : 188 Age : 50 Home City : paisley Model and year : VW TRANSPORTER T5 LWB poptop camper Registration date : 2007-11-17
 | Subject: Re: Gearbox warning light......... Tue Sep 23, 2008 8:24 am | |
| low on auto fluid maybe....or could it do with a change....? |
JohnHRef999 Been here a while
Number of posts : 150 Age : 66 Home City : Lincoln England Model and year : 1993 Hiace Campervan 4WD 2779cc Diesel Auto Transmission Registration date : 2007-07-17
 | Subject: Re: Gearbox warning light......... Tue Sep 23, 2008 7:18 pm | |
| Might be the Auto Fluid Temp- hence it went off when you stopped! Check the fluid level with the engine running and the engine hot. If its low it gets hot quick.
PS when you check the level with the engine cold and not running it looks like it is overfilled so it needs to be hot and running. The torque converter takes a lot of fluid once it starts working. |
 | Subject: Re: Gearbox warning light......... Tue Sep 23, 2008 10:23 pm | |
| Thanks for the input...have checked all of the above, only to find out that it is NOT the gearbox light, it is in fact the engine management light..  (this is why I am not a mechanic) Took Trundlebus for a run tonight and the light only came on when I was doing about 3500 rpm and then went off almost straight away... have seen the post with fault codes, and was wondering if that would help me, if so where is the diagnostic socket? |
ruffnut Hiace Master
Number of posts : 999 Age : 60 Home City : Highett Australia Model and year : kzh100 1996 Registration date : 2008-02-28
 | Subject: Re: Gearbox warning light......... Wed Sep 24, 2008 12:01 am | |
| should be under glovebox in foot well that is where mine is |
 | Subject: Re: Gearbox warning light.........  | |
