 Brake Pads
fractalias
Number of posts: 20
Home City: Sydney, NSW, Australia
Model and year: 95 SCL 3.0T 4WD
Registration date: 2008-05-29
PostSubject: Brake Pads   Wed Oct 15, 2008 7:49 am
It's just about time for my first new set of disc pads.
I was wondering if pads from a generic hiace of the same age (ie. RZH series) would go on fine ?
It would certainly make it easy for me if this is the case.
cheers
Number of posts: 148
Home City: Lincoln England
Model and year: 1993 Hiace Campervan 4WD 2779cc Diesel Auto Transmission
Registration date: 2007-07-17
PostSubject: Re: Brake Pads   Thu Oct 16, 2008 5:42 pm
Do you know the part number? ? 04465-26130
fractalias
Number of posts: 20
PostSubject: Re: Brake Pads   Fri Oct 17, 2008 8:55 am
The pads I've been looking at are bendix (db1205), which acording to the bendix site should go on pretty much every hiace from '90 to '00, although it doesn't mention a KZH model, of course
PostSubject: Re: Brake Pads   Fri Oct 17, 2008 11:15 am
I am not an expert on Chassis but Blue Print list two versions - ADT342109 upto 1993 & ADT342128 >1993
They list ADT 342109 as being specifically for the KZH model for all years, so I guess the early versions are the same for Hiace.
VOZZA
Eagle Eyes
Eagle Eyes
Number of posts: 146
Home City: SYDNEY
Model and year: 99 LIMITED 2000 UPDATE
Registration date: 2008-04-01
PostSubject: Re: Brake Pads   Sun Oct 19, 2008 9:03 pm
I was told (not by a toyota dealer) to only use genuine toyota pads otherwise the breaks will sqeak. I had this happen to me with my old local hiace. They probablly cost an arm and a leg but I hated the noise so when the time comes I think I'll cough up.
PostSubject: Re: Brake Pads   Mon Oct 20, 2008 10:23 am
I use Blue Print pads and have yet to get squeaking - I do use plenty of copper grease on the pad backs and the stopping power is brilliant. I always clean the calipers and check the pistons to ensure they move and retract to the full range. Dirt behind the rubber boots can cause piston sticking that causes brake noise on a free wheel.
Brake Pads
» REAR DISK BRAKE SET RM450
» EVO UPGRADED BRAKE KIT FRONT - USE WITH 17x8J ET25 TOMBINOS
» EVO UPGRADED BRAKE KIT REAR - USE WITH 17x8J ET25 TOMBINOS
» Brake Pads
» Help: caliper piston / brake pads
