 Lever in the dash - what is it?
PostSubject: Lever in the dash - what is it?   Sun Nov 09, 2008 5:47 pm
What is the lever set in the dash on the left hand side of the steering column. It moves through 180 degrees but don't appear to do anything?
zoochy
Home City : Tropical Canada
Model and year : LH107G 1991
PostSubject: Re: Lever in the dash - what is it?   Sun Nov 09, 2008 7:36 pm
It allows you to tilt the steering wheel when the leaver is perpendicular to the column.
PostSubject: Re: Lever in the dash - what is it?   Sun Nov 09, 2008 9:52 pm
Thank you.
I'll have a play tomorrow.
PostSubject: Re: Lever in the dash - what is it?   Mon Nov 10, 2008 2:51 am
Ours was loose when we got it and the wheel used to drop at unexpected times. The lever is on a spline if you ever have to adjust it. Just take the nut off and lever it off and adjust by repostioning on spline.
PostSubject: Re: Lever in the dash - what is it?   Mon Nov 10, 2008 8:37 am
Thanks, I assume it has moved as only a fraction of resistance then lever just falls down, may be on that today as it is raining yet again here!
PostSubject: Re: Lever in the dash - what is it?   Tue Nov 11, 2008 2:37 pm
Right lever locks the wheel fine, just move it a fraction and it falls away. I assumed that it was just not releasing, so I got myself in position to remove the trim and leant on the steering wheel it moved in about 3 inches, pulled it out and is now in a far better position for me. Lifted lever up and it is locked there. Result or what!
This bus is just getting better and better!
» Dad delivers baby in car after tunnel dash drama
» Lord Turner Chairman of FSA v ex Directors of RBS
» A Dash of Personality
