 Towing weights.
Number of posts : 1117
PostSubject: Towing weights.   Mon Jan 15, 2007 10:46 pm
This can go here...
Has anybody got any DECENT towing weight information ?
Is the 3.lt much better than the 2.4 ETC ETC
kev
Number of posts : 18
Home City : west australia
Registration date : 2007-03-23
PostSubject: Re: Towing weights.   Thu Apr 05, 2007 1:24 am
hi i tow a 5meter boat and the van does it no problem. even when we go away and it gets loaded up with camping and fishing gear it goes very good . i have found that around town its best to leave the overdrive off as the box does tend to go into top . i was told buy the auto trans joint it is best to leave od off especially in town . ifind the gearing a bit wrong for what i do but i dont like putting too many rpm on the motor so in town up to about 70 klm/hr od off and once i get to 80 + i put od back on it
seems to be the way to go
PostSubject: Re: Towing weights.   Tue Apr 10, 2007 9:48 pm
Having just come back from towing my 2 axle 21 foot caravan I agree with switching the O/D off. The engine revs too highly and changes the gears to quickly.
Other than that ... NO PROBLEM with the power.
PostSubject: Re: Towing weights.   Wed Jun 13, 2007 7:22 pm
is yours the 2.4 2.8 or3.0? only asking as mines 2.4 and will be getting a caravan at the end of the month.i got told towsure have a conversion chart so you can type in your vehicle and find out what you need.
PostSubject: Re: Towing weights.   Thu Jun 14, 2007 8:32 pm
"Bessie" is a 3.0lt.
The caravan club has an outfit matching service where you can give the details of your outfit and they will do the maths and tell you if its safe / legal.
PostSubject: Re: Towing weights.   Wed Jun 20, 2007 10:06 pm
found it here we go... http://www.caravanclub.co.uk/Practical+advice/Thinking+of+buying/Outfit+matching/Outfit+matching.htm
PostSubject: Re: Towing weights.   Sat Jul 07, 2007 8:13 am
found this if it helps anyone http://www.campingandcaravanningclub.co.uk/Documents/Matching%20Car%20and%20Caravan.pdf had my 2.4 on weighbridge with full tank it weighed 2200kgs
Pete_nz
Model and year : '95 4WD Auto 3.0TD TripleMoonRoof
Registration date : 2010-02-27
PostSubject: Re: Towing weights.   Sun Feb 28, 2010 10:14 am
Long time replying.... From what I understand, the gross towing capacity of the Supercustom is 750kg unbraked and 1400kg braked. I don't have the owner's manual so am curious if it corroborates this.
Number of posts : 98
PostSubject: Re: Towing weights.   Fri Feb 24, 2017 8:22 pm
2. Car towing weight and width limits
Most cars have a maximum weight they can tow. It’s usually listed in the handbook or specification sheet.
Alternatively the vehicle’s ‘gross train weight’ may be listed on the vehicle identification number (VIN) plate on the car. This is normally under the bonnet or inside the driver’s door.
The gross train weight is the weight of the fully-loaded car plus fully-loaded trailer and must not be exceeded.
If your VIN plate doesn’t list a train weight, you should not use your vehicle for towing.
Vegpot, 19 April 2016
Number of posts : 537
PostSubject: Re: Towing weights.   Fri Feb 24, 2017 9:14 pm
Useful info, I always wondered what that meant!
Number of posts : 582
PostSubject: Re: Towing weights.   Sun Feb 26, 2017 4:00 pm
I have the slowest engine in the Hiace, but perhaps the highest towing weight?
Max total vehicle weight is 2900kg, and the "train weight" is 4900kg on the VIN plate.
This is inline as how my vehicle is registered in our country, where a towing weight of 2000kg is listed.
I have a LH118 4x4 body type which is pretty heavy by itself, so this is the LWB (but not the extra long wheel base). I would say it is all very comparable, however, do note that I have leaf suspension instead of coil springs.
Towing weights.
» 266lbs...not lifting weights...(aka Baron Von Bulk...)
» HIIT AND Weights "Reverse" Cellular Aging
