| | Timing Belt Warning Light, how to reset? | |
| Author | Message |
Dwayne
Number of posts: 20 Model and year: 1995 KZH106G
Registration date: 2008-01-31
 | Subject: Timing Belt Warning Light, how to reset? Tue Dec 02, 2008 6:37 am | |
| Hi, does anyone know how to reset the timing belt (T-Belt) warning light on the dash of an analog odometer (once its hit 100k)? This is for a KZH106 1995 Hiace model with no tacho meter, has the door open indicator in its place. |
 | Subject: Re: Timing Belt Warning Light, how to reset? Tue Dec 02, 2008 8:31 am | |
| Toyota often have a rubber gromet in the dash glass, if you have pull it out and poke a thin stiff wire through the hole. |
Dwayne
 | Subject: Re: Timing Belt Warning Light, how to reset? Tue Dec 02, 2008 10:01 pm | |
| Hi, this has no rubber grommet on the front. I'm assuming this means its a major job where you have to get in behind the instrument cluster? |
 | Subject: Re: Timing Belt Warning Light, how to reset? Wed Dec 03, 2008 7:04 am | |
| I suspect then that there is a diagnostic type connector somewhere that you flash the pins the reset it, another Toyota secret? |
 | Subject: Re: Timing Belt Warning Light, how to reset? Wed Dec 03, 2008 9:43 am | |
| | Quote: | | assuming this means its a major job where you have to get in behind the instrument cluster? |
Removing just the clock cluster is much easier and quicker than you'd think.... I don't know how to reset...but read of access through air vents...shorting pins...pushing buttons...it all gets a bit mythical! .....but if you want to look behind the clocks don't be put off...just remove the screws from the clock shroud...then the clock panel is held with a few screws and pulls out cleanly |
Dwayne
 | Subject: Re: Timing Belt Warning Light, how to reset? Thu Dec 04, 2008 6:42 am | |
| Yeah, I've removed the dash etc a coupla times so know how to do that. The instrument cluster looks like its just fixed with 4 screws but I need the detail to reset the light! Surely someone must know....?! |
Number of posts: 453 Age: 40 Home City: Cheshire Model and year: 93 2.4 turbo supercustom limited Registration date: 2007-06-09
 | Subject: Re: Timing Belt Warning Light, how to reset? Thu Dec 04, 2008 8:30 am | |
| only thing ive ever heard(ive got digital one)is something about removing the dash unscrewing a screw(where i dont know not looked)and re screwing it back into a screw hole next to it.......mines been on a while now not got round to pulling it apart yet  |
 | Subject: Re: Timing Belt Warning Light, how to reset? Thu Dec 04, 2008 1:02 pm | |
| Toyota are often helpful and notate what is what on the printed circuit, may be obvious if it is on the back of the dash? |
 | Subject: Re: Timing Belt Warning Light, how to reset? Thu Jan 15, 2009 11:47 am | |
| Yes i would like to know how to reset my one as well - just came on the other day - i already replaced the belt - anyone know for sure because its buggin me! |
 | Subject: Re: Timing Belt Warning Light, how to reset? Thu Jan 15, 2009 3:01 pm | |
| On the Hi-Surf 2.4 there are two knobs under the speedo one does the trip meter the other restets the timing belt trip counter. I've a digital combination meter (guages) with no such switch don't even know if I get a warning either? |
 | Subject: Re: Timing Belt Warning Light, how to reset? Tue Feb 03, 2009 2:53 pm | |
| Spoke to a friend who has a later Landcruiser. On the back of the meters on the printed circuit there are two circular adjacent markings with, would you believe two holes, one has a screw in it the other don't. Simply remove screw and put it in the other one, job done for another 100.000 KMs.
Anyone got a photo that shows the back so we can have a look? |
 | Subject: Re: Timing Belt Warning Light, how to reset? Thu Feb 05, 2009 11:57 pm | |
| Ahh ok - will pull it apart this weekend and have a captain cook - let you know. Thanks Clive. |
