 Current draw on fuse 16 flattening Battery
qpv8evo
Number of posts : 22
Registration date : 2008-01-25
PostSubject: Current draw on fuse 16 flattening Battery   Mon Dec 29, 2008 7:59 am
Hi,can anybody tell me what they mean by "Stop Light" on fuse number 16?On attaching an ammeter I have got a huge current draw on this circuit which is draining the battery overnight,removing fuse 16 removes the drain,the handbook says that the fuse covers interior lights,door open warning lights,step light and stop light but the brake lamps are still working with the fuse removed,the fuse is labelled "Dome"not sure what this means,is this a japenese word for interior illumination??
I need to find out what else is on this fuse to try and find what is staying on overnight
Many Thanks in advance
Gareth
Number of posts : 1116
PostSubject: Re: Current draw on fuse 16 flattening Battery   Mon Dec 29, 2008 1:55 pm
Sounds like we have the same book. Perhaps "dome" is what they call the middle interior light ?
My book says that fuse 14 is the stop light with the description of display light.
Good luck and if you want me to pull fuses to test let me know
PostSubject: Re: Current draw on fuse 16 flattening Battery   Mon Dec 29, 2008 4:21 pm
Dome is all interior lights.
Sounds like you have a short on one of them. Pull each bulb and check with your ammeter.
qpv8evo
PostSubject: Re: Current draw on fuse 16 flattening Battery   Tue Dec 30, 2008 4:52 pm
Thanks guys,I will have to re connect the ammeter and do each at a time like suggested.
Gareth
PostSubject: Re: Current draw on fuse 16 flattening Battery   Tue Dec 30, 2008 11:10 pm
I repaired one of my interiors recently. If you are in the UK at the moment you'll probably have a fair bit of condensation above the roof lining etc....which may/may not be contributing. Worth a thought anyway
» Current Reads
» [MF] Tomoko Fuse - Enjoyable Origami to decorate your Living
» Removing Current Time/Date from PHPBB 3
» 99th Field Battery RCA
» Describe Your Current Emotion With a Gif ~
