 Where is the weight plate??
anthonyj
Number of posts : 48
Home City : Nottingham UK
Model and year : SC cruising cabin 1997
Registration date : 2008-08-27
PostSubject: Where is the weight plate??   Wed Jan 28, 2009 5:52 pm
I have looked under the passenger seat and there is a plate there which says GVM on it but no nos
Underneath it says Trans/Axle A340F G292
Does that mean anything?
Am I right this is a 3000Kg van max? mine is long wheelbase, any chance it could be 3200Kg?
Have emtied the hot water system and the canned food out and saved 50Kg but I could still do with more payload.
Any help appreciated - email me if you want anthonypjohn@yahoo.co.uk
Anthony
alfazar
Number of posts : 99
Home City : N.Ireland
PostSubject: Re: Where is the weight plate??   Mon Feb 09, 2009 4:53 pm
The codes you mentioned are only for the transmission and rear axle (type, size, ratios etc.)
I cant find a weight code either and my MOT tester was looking for it too.
anthonyj
PostSubject: Re: Where is the weight plate??   Wed Feb 11, 2009 11:44 am
Did you have any trouble with the MOT tester as a result?
Mine has had 2 UK MOTS before with the previous owner so I am hoping I won't have any trouble when its my turn in June.
I have come to the conclusion that if the vehicle looks like its loaded ok and feels ok when driving then it probably is ok. After all no one seems to be able to say what the top load should be - including Toyota.
alfazar
PostSubject: Re: Where is the weight plate??   Thu Feb 12, 2009 11:13 am
The van MOT'd no problem. The tester asked me where the weight plate was, neither of us could find it, but then he said it didn't really matter anyway, which seemed odd?
I think it's only a big deal if it was being tested as a goods vehicle or a minicab. Mine is taxed Private/light goods (PLG).
I'm in Northern Ireland, so it's same as a GB vosa test but our test centres are purpose built govt buildings, not garage based as in GB. Our testers have a reputation of being pretty strict and things like brakes, shocks and headlights seem to be judged by a computer. The only slightly unusual thing was that he had to move the van into a different test lane because van is 4wd; needed to use a different set of rollers for the brake test. The van had previously been MOT'd in England.
From looking around the web I can only see a few references to GVW. Most seem to be around the 2800kg mark. The newer UK spec 1995> Hiace with the engine out front is 2800kg SWB and 3000kg for the LWB.
There are Unladed weights on this site if it's any help.
http://www.cars-directory.net/specs/toyota/hiace/
trevor999
Number of posts : 22
Home City : Caerphilly South Wales
Registration date : 2008-02-05
PostSubject: gvw   Thu Feb 12, 2009 8:42 pm
Hi
Have you tried your local caravan dealer found some pretty hopeful
Trev
jumoto
Number of posts : 17
Home City : Halle, Germany
Model and year : KZH100 Supercustom G 1996 3.0TD EFI
Registration date : 2010-06-03
PostSubject: Re: Where is the weight plate??   Mon Jun 28, 2010 10:31 am
what does private/light goods mean? do you pay less taxes?
what is the rear axle load for the g292 in the 1996 hiace supercustom? does anyone have a copy of his mot where i can see the rear axle load?
many thanks
dandywarhol
Number of posts : 163
PostSubject: Re: Where is the weight plate??   Mon Jun 28, 2010 8:17 pm
If its any use I put my long wheelbase semi hitop camper on the scales last week and it tipped in at 2460kg. Thats before ading the tins of food!
gg66
Home City : na
Registration date : 2012-05-16
PostSubject: Re: Where is the weight plate??   Wed May 16, 2012 11:16 am
I was also looking for the location of the wright plate but can't find it. I have an export cert which has some details and may be of use to someone else on the same search.
Toyota Hiace Cruising Cabin - long wheel base
Model: U-LH129V
Vehicle Weight - 2540
Gross vehicle weight - 2870
Lenght - 545
Width 169
Height - 258
F.F. Axle Load - 1230
R.R. Axle load 1310
gg66
Home City : na
PostSubject: Re: Where is the weight plate??   Thu Aug 07, 2014 2:52 pm
Has anyone managed to find official verification of the GVW
Inspector refused to pass my cruising cabin without confirmation from Toyota who say they can't provide it for japanese imports
Tested fine before so this is a pain
Number of posts : 186
PostSubject: Re: Where is the weight plate??   Tue Aug 12, 2014 7:14 pm
Did you find this in the end? ISTR it's under the carpet on top of the front wheel arch on the passenger side?
» For all the people interested in losing weight
» Dallas (TNT)
» Now that's what I call Sportsmanship
» Lexis Roberts -- Found Deceased 10/8/10, Suellen Roberts -- Found Deceased 11/15/10
