 front grille/indicator lamp removal
motorwaydrifter
Number of posts : 16
Registration date : 2009-02-03
PostSubject: front grille/indicator lamp removal   Fri Feb 20, 2009 12:40 pm
Hi all.I need to remove the front grille and all related bits before that.I can see the grille is held on with push clips but how the king hell do I get the outer lamps off!!!!I'm an intelligent sort of chap but I must have a blind spot where this is concerned.I assume once I've dine this I can get at the washer jets or am I completely on the wrong track??Help please divorce pending!!!!!Doug confused confused confused
alfazar
Number of posts : 99
Home City : N.Ireland
PostSubject: Re: front grille/indicator lamp removal   Fri Feb 20, 2009 12:49 pm
Open the doors. Look down the edge of the body behind where the lamps are. You should see one phillips head screw and a small empty hole (above or below it, I can't remember which) Take out the screw and then pass a screwdriver through that other empty hole and give it a sharp tap. The lamp should fall out.
That's what works for me, not sure if it's the "right" way to do it.
PostSubject: Re: front grille/indicator lamp removal   Fri Feb 20, 2009 1:15 pm
if your on about the screen washers i had a pipe come off in the frost,this brought water in whenever i squirted them.mechanic wasnt best pleased as he said it was tighter than a mouses ear(not a hippopotamouse)to work behind the dash so i presume the pipes run internally.
mattyj
Number of posts : 118
Home City : Liverpool Sydney
Model and year : 92 Toyota Hi-ace 4x4 Super custom non turbo
Registration date : 2010-08-05
PostSubject: Re: front grille/indicator lamp removal   Thu Sep 09, 2010 11:38 am
VOZZA
Number of posts : 150
Home City : SYDNEY
PostSubject: Re: front grille/indicator lamp removal   Fri Sep 10, 2010 12:13 am
All wrong guys, removing the grill or headlamps will not get you to the washer nozzles/pipes, vey hard to get to under the dash. So much so that I have given up for the time being and am living without them. Keeps the bums/junkies at the lights with thier squeegies in business Laughing Maybe Maximus' mechanic can shed some light on how he got to them.
» Daily Express front page
