 meter warning sign....
cjhhtml
Number of posts : 38
Registration date : 2009-02-23
PostSubject: meter warning sign....   Fri Apr 03, 2009 10:02 pm
hello everybody,
my S.C. is year 1999,
with 1kz engine,auto,
my meter is digital type,
there got some warning sign which i donn't know what mean,
at the bottom left hand side of the meter there,
got a timing belt warning sign,
beside the timing belt warning sign,got 3 wairing sign,
from left to right,the 1st 1 if i not misstaken is the fuel filter water level,correct me if i am wrong,
the middle 1 look like motor oil pressure warning light but got a line at the bottom,what mean of this sign?
and the 3nd is some ting look like radiator,what mean of this sign ?
thanks
want33s
Number of posts : 76
Home City : Sunshine Coast. Queensland Australia
Model and year : LH107... 1989 4x4
Registration date : 2008-10-02
PostSubject: Re: meter warning sign....   Fri Apr 03, 2009 11:07 pm
Can you post a photo please?
cjhhtml
PostSubject: Re: meter warning sign....   Sat Apr 04, 2009 6:20 am
em..........
sorry,
can i know how to post pic ?
PostSubject: Re: meter warning sign....   Sat Apr 04, 2009 10:38 am
Try this
http://hiace-super-custom.free-boards.net/show-us-yours-f6/how-to-upload-a-picture-t12.htm?highlight=post+a+picture
But I guess if orange fuel filter water level
Low engine oil?
Low coolant.
Number of posts : 1116
PostSubject: Re: meter warning sign....   Sat Apr 04, 2009 4:51 pm
cjhhtml
PostSubject: Re: meter warning sign....   Sat Apr 04, 2009 9:36 pm
thanks admin,
on 1st of april,
i am driving my S.C challenge a road in my place here,
this road i almost the most dificult road in my place here,
70% i hill climbing,
long hill climbing,
in my ride i already change the radiator fluid,add in new toyota coolent,
change the silicon oil for the viscous fan,
change motor oil,15w40,
add extra motor oil cooler,
add extra ATF cooler,
add a 12 inch electric fan in front of the main radiator,
the secondary radiator fan is always on when engine started,
i do all this,
when climbing hill,
my ride over heat,
the 3 warning sign come out 1 by 1.
PostSubject: Re: meter warning sign....   Sun Apr 05, 2009 1:30 am
First which lights came on? From the left.
Then a few causes, hope it's not the first Sad
Cracked head ??? thermostat stuffed, Auto gearbox overheating which would bring up main radiator heat through the cooling lines
Hope you get this sorted mate
PostSubject: Re: meter warning sign....   Sun Apr 05, 2009 5:14 pm
Having the front and rear heaters on full blast at the critical point will help cool things.
I used to have a cheap multimeter with temperature function...the probe wire was stuffed into the side of the temp switch on the head and silconed over.....
OK..the reading was rough as not immersed in coolant ...but it showed relative changes while driving....when it got to a certain figure I'd hit the fans...
Clive will probably remember the townace modification of the temp guage....also I think John replaced his townace guage with something more accurate...
PostSubject: Re: meter warning sign....   Sun Apr 05, 2009 11:15 pm
Yes the Mason Alarm (have a look on www.townace.com for it)
John fitted an aftermarket guage that showed the temp not just a point somewhere between c and H or if you have a digital one like me a little green square near the middle of the display.
» Personalized Profile fields / Warning System
» Warning system?
» Progress Bar/Meter for Posts and Topics
» FTP site sign in
