 Leaking camper
johnny
Home City : A CAMPSITE NEAR YOU
Registration date : 2008-03-09
PostSubject: Leaking camper   Sun Apr 26, 2009 7:19 pm
Hello i wonder if any other owners have had this problem or know how to sort it out ,i have a smallish amount of clean water not coolant appear in the passenger footwell after heavy rain or washing with a hose i have removed glove box but cant see where it is coming from ,also how do i remove the plastic trim on the front of the van where the toyota badge is sorry forgot to mention van is a import hiace am craft hi top camper thanks johnny
robysam
Number of posts : 14
Home City : Chester, UK
Model and year : KZH138 4x4 Camper3L Turbo Diesel 1995
Registration date : 2009-07-27
PostSubject: same leak   Sun Jan 03, 2010 7:20 pm
Hi Johnny,
Did you find a solution to your leak?
I have the same issue - carpet up at the moment drying out!
Rob
Im not old...just experienced
Number of posts : 324
Home City : Sandhurst, UK
PostSubject: Re: Leaking camper   Sun Jan 03, 2010 9:29 pm
check the window rubber, there is a chance its perished and allowing water in, also worth checking the door rubber and finally the sunroof ( if you have one), the drain could be blocked allowing water into the van, happened at the rear of my mx-5 when the drain blocked..
if these are ok then i'd take off the front grill and check that there are no loose rubber grommets..
To take the grill off, remove the indicator / sidelight unit, this should uncover bolts, undue these and it should then pop off
Andy
PostSubject: Re: Leaking camper   Mon Jan 04, 2010 7:01 pm
There is a how to on removing grill here somewhere. Does the camper have the same drain hose as the sky roof panels? If so it may be blocked and letting water in.
robysam
PostSubject: Re: Leaking camper   Sun May 29, 2011 5:09 pm
My leak isn't from the grill as seems to come from higher up.
I don't have a sunroof but suspect the window seal so am getting it redone.
PostSubject: Re: Leaking camper   Mon May 30, 2011 11:36 am
Window washer jets not seal to the body work?
Most common is the sunroof rains pipe but as you don't have one.
Let us know how you get on.
PostSubject: Re: Leaking camper   Mon May 30, 2011 1:27 pm
+ the windscreen washer plastic pipework runs inside.....
robysam
PostSubject: Re: Leaking camper   Mon May 30, 2011 1:41 pm
Clive, thanks for suggestion.
Thanks to the weather have had a closer inspection.
Took the speaker unit out and noticed a steady drip from the welded seam running under the windscreen. Starngely there is also some sort of drainage pipe which appears to originate in the same area as the leak and dangles through a grommet to terminate outside - it's not blocked and drips are coming through it but I have no idea what it could be draining? I cant see behind the welded seam unfortunately
All comments welcome ..... scratch
PostSubject: Re: Leaking camper   Mon May 30, 2011 6:46 pm
Heater/ A/C condensation drainage?
robysam
PostSubject: Re: Leaking camper   Mon May 30, 2011 6:52 pm
Would have thought that Heater/ A/C condensation drainage would be lower down.
This is right in the corner of the windscreen
PostSubject: Re: Leaking camper   Mon May 30, 2011 11:13 pm
You may have had a sunroof etc. before the hi top was fitted?....
Fiona
Number of posts : 164
Home City : Brinsmead, QLD, Australia
Registration date : 2010-04-11
PostSubject: Re: Leaking camper   Mon Jul 04, 2011 3:49 pm
hmmmmm mine leaks badly on the drivers side but also the passenger side when it rains. i suspect it the windscreen seal but with out a knowing for sure its a lot of money to replace if its not it.
H8wrk
Home City : Paraparaumu, New Zealand
Model and year : 1998 KZH106 3l turbo 4wd manual
Registration date : 2011-08-14
PostSubject: Re: Leaking camper   Sun Aug 14, 2011 7:10 am
@ robysam: On both bottom corners of the windscreen apperture there are drain holes with pipes leading to the outside, That is probably what you have found. Common fault to find is that the foam seal that goes between the pipe and body has perished, unfortunately this requires removal of the windscreen to rectify.
Another common fault seen alot in my trade is as Clive suggested, the washer stalks leak notoriously.
Hope this helps
Leaking camper
