 Rear Brake Lights
spannera
Number of posts : 11
Home City : Toowoomba Australia
Registration date : 2008-06-24
PostSubject: Rear Brake Lights   Sun May 03, 2009 8:40 am
Ok, so I've pulled the car apart. I have only one brake light that has been installed above the curtain in the rear of the van. I have looked on both sides at the rear and discovered no power to the the left and right warning lights that also come on when the headlights are on.
So I playing a guessing game, but am thinking that the installed light above the curtain is connected to original wiring on the back door. So can someone confirm:
1) On the actual opening rear door, were these where brake Lights (and reversing light) lights used to be on my car?
And
2) How do you get to the wiring / bulbs on the rear opening door if this is the case??
I am guessing if this is the case the previous owner has connected his newly installed brake light above the curtain to the these!!!..
Any help appreciated.
John
Number of posts : 995
PostSubject: Re: Rear Brake Lights   Sun May 03, 2009 11:02 am
ok john the lights in the rear door are behind the lining on the door and these are connected to the original wiring and i believe they are t10 globes
cheers
dave
PostSubject: Re: Rear Brake Lights   Mon May 04, 2009 4:29 am
The bulbs and wiring weren't in mine. Got a leccie to fit them up. The tail lights aren't all that bright but the stop lights are good. The top one on mine is a bit on the dark side because of the tint.
spannera
PostSubject: Re: Rear Brake Lights   Mon May 04, 2009 8:06 am
Thanks all...
I ended up putting a meter on the existing wires to the sides. I found that everything was actually wired up for the bottom side brake lights, however.. the bulb that was used was a standard brake/stop bulb with the 2 contact points. Whilst the wiring was working, I ended up buying new ones with longer contact points down the bottom and they now work.
Cheers.
John
fractalias
Number of posts : 20
Home City : Sydney, NSW, Australia
Model and year : 95 SCL 3.0T 4WD
Registration date : 2008-05-29
PostSubject: Re: Rear Brake Lights   Tue May 19, 2009 4:17 am
my tailgate lights don't work either.
i went searching around in the tailgate expecting to find blown bulbs. i found there was some wiring but bulb holders have been removed and wires cut pretty short. I was pretty disappointed. Would like to get them up and running at some point.
existing tail lights are pretty dull too!
Rear Brake Lights
» Lights Poxleitner
» What Are You Watching
» Breaking Christmas lights
» How to add Christmas lights to the site.
