 Power sliding door
cjhhtml
Number of posts : 38
Registration date : 2009-02-23
PostSubject: Power sliding door   Mon May 04, 2009 11:01 pm
does anyone S.C. here got using power sliding door ?
unfortunatly my S.C. didn't have.
i am looking a 2nd hand set of power sliding door for my S.C.
is it the power sliding door can open and close the sliding door just press the button ?
is it easily modify it ?
thanks.
PostSubject: Re: Power sliding door   Tue May 05, 2009 7:57 am
Mine just has the soft close motors. Instead of slide and slam the motors take control of the last bit and gently pull the door in and lock it.
cjhhtml
PostSubject: Re: Power sliding door   Tue May 05, 2009 8:49 pm
my S.C. also got that function as what you say,
people in my place here call it vacuum door,
got for the sliding door and also back door,
the sliding door opened,
you just need simply pull the door,
the door run run run near to close.
the door will automatic close,
or the door didn't close propely,
the door will close automatic,
but this function is just for the sliding door is near to close,
it just will close automatic,
but when you pull the door not enough,
the sliding door is on half way,
it will not close.
i am looking for is power sliding door,
( if i not miss taken, ) which is you can open or close the sliding door just press a switch on the dash board,
someting like toyota ALPHAD.
jerome vapor
Number of posts : 21
Home City : Ormoc City, Leyte, Philippines
Model and year : toyota super custom 1993
Registration date : 2009-08-06
PostSubject: Re: Power sliding door   Sat Sep 12, 2009 4:34 pm
Sir, Its like in a bus that hydraulic power on it and with additional mechanism on it run by an electronic. It can be modified... study Smile
Power sliding door
» Browning Hi Power Holster
» Canadian Hi Power..... airsoft
» NHS - The McCanns Abuse of Power
