 Reseting timing belt light
zoochy
Home City : Tropical Canada
Model and year : LH107G 1991
PostSubject: Reseting timing belt light   Mon Jun 15, 2009 10:55 pm
The timing belt change light comes on every time you roll 100,000 kilometres regardless of when the belt is actually changed. To reset it, remove the lower right section of the dashboard by removing the 2 screws that hold on the fuel filler cover lever.
There is a screw in the little white piece of plastic that is just left of the key lock for the ignition (where the screwdriver is pointing):
Remove the screw and move it to the other hole. This toggles the timing light between being on for odd or even 100,000s of kms. When your light comes on again after another 100,000 km move it back to the original position.
Now if only changing the timing belt itself were that easy... More pictures to follow.
PostSubject: Re: Reseting timing belt light   Tue Jun 16, 2009 10:01 am
So in theory if your light is not on and you move the screw it should then be on?
Thanks for that.
On the 1KZ-TE engine the timing belt is that easy!
zoochy
PostSubject: Re: Reseting timing belt light   Tue Jun 16, 2009 11:13 pm
Yes in theory, it should come on.
PostSubject: Re: Reseting timing belt light   Thu Jun 18, 2009 11:24 am
Good one , thanks for that mate.Got another 20k to go before I need it.
Dwayne
Number of posts : 21
Model and year : 1995 KZH106G
Registration date : 2008-01-31
PostSubject: Re: Reseting timing belt light   Sat Jul 11, 2009 7:46 am
Fantastic...I was hoping someone would post this info!
I thought you had to take out the whole dash but this looks relatively painless.
PostSubject: Re: Reseting timing belt light   Sat Jul 11, 2009 11:31 am
Yeah dont worry you still might have to... mine is nothing like zoochys, will have to take whole dash out one of these days.
Dwayne
PostSubject: Re: Reseting timing belt light   Mon Jul 13, 2009 11:46 am
Dang....yeah I've seen a picture somewhere that shows the same type of screw holes on the back of the dash/combination meter circuit board...ie you have to remove the meter....havent checked mine yet!
zawmintun
Home City : yangon
Registration date : 2011-06-25
PostSubject: Re: Reseting timing belt light   Mon Sep 05, 2011 7:36 pm
I cannot find the screw to reset the timing belt light in my 1999 model super custom 4wd living saloon ex
PostSubject: Re: Reseting timing belt light   Wed Sep 07, 2011 11:07 am
Yeah mate i never found mine either, think its different on the newer models. My lamp eventually went out. Shocked
hattonhall
Home City : Woodridge
Model and year : Super Custom Hiace 1988
Registration date : 2011-12-11
PostSubject: Thanks for this one!   Sun Dec 11, 2011 6:57 am
I had kinda gotten used to that little light..........but now she just has to go!
cheers
Number of posts : 107
PostSubject: Re: Reseting timing belt light   Wed May 23, 2012 12:33 pm
How often do you need change the timing belt in the 2.8ltr (1993). Was reading in the manual and it reckoned every 10,000 miles, which ead liek a misprint to me surely?
PostSubject: Re: Reseting timing belt light   Wed May 23, 2012 12:35 pm
ps. cheers for letting me know how to remove that bottom right panel, has been vexing me and the factory fit speakers are seriously in need of replacement....
PostSubject: Re: Reseting timing belt light   Wed May 23, 2012 3:22 pm
I think 100,000 kms would be right....
Number of posts : 84
PostSubject: Re: Reseting timing belt light   Thu May 24, 2012 9:15 am
Toldsimply - the timing belt light on my 1991 2.8l came on at 90,000km. The vehicle was imported used from Japan so no knowing how genuine those kms are.
cornishpasty
Number of posts : 7
Home City : truro
Model and year : 1994 hiace custom 4wd
Registration date : 2012-02-04
PostSubject: timing belt light   Thu Jul 05, 2012 7:54 pm
Just to say i have just reset the light on my mothers 95 super long hi-top (its a base spec van) and the screw is in the back of the dash binnacle and clearly marked, my 94 custom looks the same, i think its only the sc's that you can reset with the clocks in place. it takes a bit longer but still relatively straight foward. wouldn't have had a clue how to reset it without looking on this forum, so thanks again to all those that post on here.
Elusive
Number of posts : 15
Home City : Tauranga, New Zealand
Model and year : 1994 Supercustom, Lowered on 18" Lenso Mags, 5% Rear Tints 35% Front tints.
Registration date : 2011-02-27
PostSubject: Re: Reseting timing belt light   Tue Aug 14, 2012 12:56 pm
The KZH100 series Super custom (08/93 upto around the 99 era) are on the back of the dash cluster.
You need to remove the bottom panel as shown above, then remove the black surround that is around speedo cluster/airvents/radio/buttons, to do this part is very tricky (hidden screws up inside the air vents in the center of the dash) and time consuming, it normally requires the clock and extra buttons to be unplugged (be careful as the clock and the hazard lights are the same style plug on most vans).
Then the speedo comes out with 4 screws around it. Once out there are 3-4 plugs on the back of it which need to be unplugged and you will see the screw marked "timing belt" move the screw over one hole and reinstall all your dash in the opposite order to above.
Hope this helps someone down the line.
