| Author | Message |
Number of posts: 453 Age: 40 Home City: Cheshire Model and year: 93 2.4 turbo supercustom limited Registration date: 2007-06-09
 | Subject: fault codes Mon Jun 11, 2007 1:47 pm | |
| hi all this is my first post. i have had a power loss problem that ive lived with for about a year and a half(due to nobody bieng able to diagnose it).the car is currently away for diagnostics (think i have the right man this time).during this time i have trawled the net for anything about my engines fault codes as it has brought two codes up(if i am right)these were sourced from various hilux sites.am i right in thinking that these codes are the same for our engines(mines a 2.4 2lte)as i cant find em on the site?toyota read the codes told me the numbers then told me they didnt know what they meant i think they go from 1-13.does anybody know? |
Admin Admin
 | Subject: Re: fault codes Mon Jun 11, 2007 5:16 pm | |
| Sorry m8 havent a clue. If anyone has a source for a good manual please post a link  |
Spud_Gun
Number of posts: 200 Age: 33 Home City: Taunton, Somerset UK Registration date: 2007-02-06
 | Subject: Re: fault codes Mon Jun 11, 2007 5:50 pm | |
| Had some time on my hands and found the following site; www.off-road.com/toyota/tech/codes/ give that a go, might help. Also has a contact to which you can askquestions more specific to the problem.  |
 | Subject: Re: fault codes Tue Jun 12, 2007 12:51 pm | |
| cheers for the quick reply spoke to the diesel guy and he has only briefly driven it he thinks its pump timing will let ya know.also thanks for the link spotted that site a long time ago and it confused me more with them fault codes.heres a link to a cracking site i came across (if the mechanicals of the engines are the same.i think so) http://www.toyotasurf.asn.au/techsite/index.htm .after checking the fault codes myself linking te1 +e1 and counting the pauses between the flashes i am presuming mines obd1.you can find your diagnostic port in the compartment were the battery is located,just dont expect anyone in england to be able to plug into it(not even toyota)  .there are plenty of usefull engine diagnosis tips on that site i would have joined to ask for advice but a: i dont own a 4x4(they may take the huff) and b: they probably wouldnt like a pomm asking for advice(without a 4x4).
 | Subject: Re: fault codes Mon Jun 18, 2007 11:28 am | |
| aha im a bit nearer sorting fault been diagnosed as overboosting(15+) vac lines been ruled out so could be a sticky actuator( i hope). |
 | Subject: Re: fault codes Fri Jun 22, 2007 5:00 pm | |
| power loss diagnosed as the actuator diaphram goosed.diesel bob had it off said i need new un.hopefully a replacement can be sourced reasonably quickly.otherwise its probably a tearfull call to the main dealer.  maybe they are a common thing that can be sourced local i dunno?
 | Subject: Re: fault codes Sun Jul 01, 2007 12:34 pm | |
| here is a link to codes specific to the 2lte engine and how to read them http://www.toyotasurf.asn.au/techsite/efifaultcodes.htm |
 | Subject: Re: fault codes Thu Jul 12, 2007 7:10 pm | |
| yahoo one toyota actuator from japan £175 plus vat and she`s back on the road  cant thank this man enough he is so helpfull and he has an excellent website why not take a look.i aint kiddin http://www.dieselbob.co.uk/ |
 | Subject: Re: fault codes Tue Nov 25, 2008 4:40 pm | |
| Do fault codes ever flash on the air con switch? Some time ago (around 3 years) it used to flash 3 or 4 times rythmically a few times...then go off. By switching the air con off and on it would start again. Did'nt appear to have any effect on the air con functionallity....but after a few weeks the light went out altogether...though the air con continued to work. Prior to that episode the switch light worked as you would expect. Anyone know what it was trying to tell me?? |
 | Subject: Re: fault codes Tue Nov 25, 2008 6:23 pm | |
|  not seen that one sorry |
mr freeze
Number of posts: 148 Home City: Sydney South Model and year: 99 SC 4WD 1KZ-TE Registration date: 2008-07-14
 | Subject: Re: fault codes Wed Nov 26, 2008 7:36 am | |
| Corollas and Camrys will flash light on the A/C switch if there is a problem, never seen a Hiace do it. Sometimes the compressor has a slip sensor and reads the revolutions of the compressor campared to the engine. tells you if A/C the belt needs tightening . Also a PCB under the dash can play up. |
