martinnz
Number of posts: 22 Age: 46 Home City: Auckland, New Zealand Model and year: Hiace Supercustom
2.4 EFI Turbo diesel
1993 Registration date: 2007-12-15
 | Subject: Front fog / driving lights (amber colour) not working Thu Sep 10, 2009 2:17 am | |
| Problem: Front fog / driving lights - amber colour built into headlight unit not working. - Failed WOF (Warrant of fitness) in New Zealand - similar to MOT butevery 6 months here. These used to work but suddenly both stopped one day about a year ago.
Solution, removed, front indicators, front sidelights Main front grill & Headlights to gain access to the halogen clear bulbs ( the amber comes from covers in the light unit) - checked the bulbs - all working - replaced the above back ( bit of a mission as the push in lugs rust up and get stuck in the rubber mounting grommets.
Inside cabin, removed fuse cover and checked fuse - OK, removed steering shroud & RH cover from below dashboard. Traced the wires from the indicator colum switch ( turns on lights, side lights & should turn on the fog lights!. using a battery a bulb & a process of elimination found that the following wires control each function. White 1 to red = side lights on White 2 to red = Head lights on Blue to black = fog lights on.
When i put a link wire on the connector block between the black & blue, the relay clicked and the fog lights came on. problem was the indicator mounted colum twist switch. As I didnt have time to replace this I rewired the balck & blue wires to a fog light switch that I had placed in an empty cutout in the dash - near to the where the ignition key goes. So now all good its passed the Wof and I can enjoy driving it again.
All sweet. I will replace it properly when I am at the wreckers next and can be bothered to paly around removing all of the steering stuff etc.
Next front interior lights not working - wiring...... |
 | Subject: Re: Front fog / driving lights (amber colour) not working Thu Sep 10, 2009 3:06 pm | |
| May be a simple dry joint in the switch? |
martinnz
 | Subject: Re: Front fog / driving lights (amber colour) not working Thu Sep 10, 2009 10:55 pm | |
| Hi Clive,
May be but I couldnt see how to get the swicth appart, any ideas? I do not have a manual for the Hiace, must get one.
Cheers |
 | Subject: Re: Front fog / driving lights (amber colour) not working Sun Sep 13, 2009 1:54 pm | |
| Not taken one apart but I do know that Toyota don't expect them to fail so they are near enough sealed for life. Take it apart slowly and carefully. |
 | Subject: Re: Front fog / driving lights (amber colour) not working Sun Sep 13, 2009 8:03 pm | |
| I had this problem...the problem was in the lighting unit. I honestly can't remember exactly what sorted it...but it was a contact issue....(grey cells working  )... It was the contacts in the male/female connector  |
