 cylinder head and radiator dead
kato
Number of posts : 10
Home City : Newton abbot
Model and year : 3.0td custom hiace camper 96
Registration date : 2007-06-23
PostSubject: cylinder head and radiator dead   Wed Sep 23, 2009 11:20 pm
Hi all in desperate need for advice, I need a new head due to mutiple cracks and a radiator which looks like it feeds two more radiators so has 4 water outlets which I can't find anywhere ive found a replacment head although would like a bit cheaper than 550 can anyone help? cheers Kato Raining (Lee)
martinnz
Number of posts : 34
Home City : Auckland, New Zealand
Model and year : Hiace Supercustom
2.4 EFI Turbo diesel
1993
Registration date : 2007-12-15
PostSubject: Re: cylinder head and radiator dead   Wed Sep 23, 2009 11:36 pm
Hi There Lee,
Sorry to hear about your problems.
I dont know much about the cylinder head, but Ive had a leaky radiator and replaced it.
The radiator fitted is very complicated and rare as it has lots of extra pipes and an inbuilt Auto transmission cooler, I tried the usual radiator repair shops here. they had manual ones - no Auto cooler, but nothing else appart from recondition. I got a quote from Toyota and that was over $1000NZD. In the end I found one at a breakers. It cost $140 NZD to buy and $70NZD to pressure test before I bought it. Pressure test was OK, so I bought it. Its a mission to fit it and took me about 6 hours - I think there are instructions here on the forum.
Ive still got the old one in the garage which I will have recondtioned when I next have a problem - I can take some photos of it if that would help??.
Best advice if you cant find a replacement, is to get it out and get it reconditioned price here was $400NZD
PS not many places here wanted to do the fitting work as it is a bit of a mission.
Best of luck
Martin
PS 1 UK pound = $2.35 NZD roughly.
PostSubject: Re: cylinder head and radiator dead   Mon Sep 28, 2009 1:41 pm
Rad recore are cheaper than new ones.
I normal vertical normal rad and one horizontal rad under the front, they have smaller A/C heat exchangers bolted to them so that may be the four you have found?
If you need to use a garage try Gary owner of GT Motors in Newton Abott, tell him Townaceclive of TEOC sent you.
jerome vapor
Number of posts : 21
Home City : Ormoc City, Leyte, Philippines
Model and year : toyota super custom 1993
Registration date : 2009-08-06
PostSubject: Re: cylinder head and radiator dead   Tue Sep 29, 2009 2:32 pm
sir, i just change my cylinder head and overhauled my radiator last june09. The cylinder head here in the Philippines cost me around ph20,000.00. FYI. Thanks. Smile
» CLINTON DOCTOR WHO CONFIRMED HILLARY'S BRAIN TUMOR FOUND DEAD.
» Man caught driving with dead body
» Does Gerry admit to knowing Madeleine is dead!!!!!
» Two women 'caught trying to smuggle dead relative on to passenger jet at Liverpool airport'
