 Engine stop within 5 mins or less
jerome vapor
Number of posts : 21
Home City : Ormoc City, Leyte, Philippines
Model and year : toyota super custom 1993
Registration date : 2009-08-06
PostSubject: Engine stop within 5 mins or less   Sat Sep 26, 2009 12:07 am
Does anyone experience with this situation. Engine stop within 5 mins or less either on park or driving. Some mechanic say that its in my computer box or the fuel pump injection and some say its in my turbo. Please help me. My mechanic will check this sunday and i want to know something about it. Thanks. confused
PostSubject: Re: Engine stop within 5 mins or less   Mon Sep 28, 2009 1:44 pm
Not the turbo.
Could be ECU problem.
If it coughs and splutters to a halt could be fulling/injection pump.
jerome vapor
PostSubject: Re: Engine stop within 5 mins or less   Mon Sep 28, 2009 3:46 pm
Thank you so much sir. My mechanic refer our forum site. Specially that engine management fault codes and how to read them under members guide. Im so glad being a member here. But still my SC is under observation. Once it will coughs and splutters again then it needs to change the injection pump as per to my mechanic. Thanks for that reply. Idea Very Happy
Dane
Number of posts : 23
Home City : Hibberdene, KZN, South Africa
Model and year : 1994 Toyota Hi Ace Super Custom 3L Turbo Diesel full time 4x4
Registration date : 2010-04-03
PostSubject: Re: Engine stop within 5 mins or less   Tue Aug 02, 2011 11:26 am
Hi
Did you get this - by mow somewhat old - problem resolved and what was foumd? The ECU faulty? Where did you get another?
View user profile http://www.artonly.co.za
jimmybob405
Home City : worthing sussex uk
Model and year : toyota hi-ace super custom lifestyle saloon 1993
Registration date : 2012-11-01
PostSubject: Re: Engine stop within 5 mins or less   Thu Nov 01, 2012 9:44 pm
hi there
i have a 1993 hiace super custom i think the engine is a 2.2 turbo diesel
i have a starting issue
when i turn the key to start it i fires then stops but when i hold the key in start
position the engine will run any idea what this problem could be
please help regards jimmy
PostSubject: Re: Engine stop within 5 mins or less   Thu Nov 01, 2012 10:47 pm
Jimmy...I had that problem on an old passat once.....its the ignition switch at the end of the locking barrel....it was an easy fix...new ignition switch
labscty
Home City : high wycombe
Registration date : 2014-09-28
PostSubject: Re: Engine stop within 5 mins or less   Mon Sep 29, 2014 8:30 pm
jimmy my motor does the same as yrs.did you find a cure my 93 30 litre turbo diesel been of rd for 5 months..missing driving it..someone said was over fueling any advise regards ricky
cordillera
Number of posts : 13
Home City : Baguio
Model and year : 1992 Hi Ace Super Custom RH drive converted to left hand
Registration date : 2014-01-01
PostSubject: Re: Engine stop within 5 mins or less   Fri Jan 16, 2015 12:50 am
This problem can be one of several things..so start with the cheapest....
1) Hole in fuel line or diaphram in hand pump, or loose connection.in fuel line..so it will get air in the line...
2) Fuel filter loose..or clogged
3) Electrical shut off for engine...wire is grounding out somewhere and shutting engine off
4) Injector pump
5) Clogged fuel pickup in tank...so people let the little foil from top of fuel additives fall into tank...
as a note...my HiAce was smoking when I had accelerator half way down or more...thought I needed a ring job...or injectors...turns out all I needed was injector pump calibration...they took it off and put it on a machine....cost me 150 canadian...now it runs like new van
» The McCanns Have Gone Over The Top. Itís Time To Stop This Farce/old article. May 12
» Can I stop email notifications for a short time
» Advocate Keith Neville ordered to stop work with veterans' appeals
» How To Stop Background Tiling & Font Color
