| Author | Message |
MNC
Number of posts: 97 Home City: Wellington, New Zealand Model and year: 1996 SC LTD 3LDT Registration date: 2009-09-21
 | Subject: Turbo Timer - Required? Sun Sep 27, 2009 8:20 pm | |
| Hey there team,
Just wanting to know if anyone has a turbo timer in their SC?
Being a turbo vehicle, i would think that this maybe required but on the other hand, its not a petrol high performing vehicle therefor the necessity of a timer to cool down the engine will not be needed?
any ideas on the matter? |
Admin Admin
 | Subject: Re: Turbo Timer - Required? Sun Sep 27, 2009 8:29 pm | |
| I have one fitted. It was already on when I bought it so I dont know too much about it. Its from FATTDC.
http://www.thor-racing.co.uk/Blitz_Turbo_Timer_FATT_DC-BLZ_FATTDC.asp
I always get asked if I forgot to turn the van off. |
 | Subject: Re: Turbo Timer - Required? Mon Sep 28, 2009 10:52 am | |
| Temp of the Diesel turbo does not get hot enough but it is good to circulate the coolant for a minute after run, not needed on around town use. |
MNC
 | Subject: Re: Turbo Timer - Required? Mon Sep 28, 2009 11:36 pm | |
| Cool cheers,
Ill be looking at getting one regardless, look after the girl and she'll look after you lol. |
Number of posts: 907 Age: 54 Home City: Highett Australia Model and year: kzh100 1996 Registration date: 2008-02-28
 | Subject: Re: Turbo Timer - Required? Tue Sep 29, 2009 9:22 am | |
| regarding timer my owners manual says that you should allow the turbo to cool after a run at 100kph so a timer would be a good idea i will now look into it myself  dave |
Number of posts: 324 Age: 42 Home City: Sandhurst, UK Model and year: 1996 Super Custom Ltd. 3.0 TDI EFI Registration date: 2009-09-19
 | Subject: Re: Turbo Timer - Required? Tue Sep 29, 2009 7:32 pm | |
| got one on mine, but keeps going for 60 secs, which is really annoying after a 10 min drive at low speeds. I'm thinking of removing it and then just do it manually if its been on a long journey.
Andy |
MNC
 | Subject: Re: Turbo Timer - Required? Tue Sep 29, 2009 7:44 pm | |
| The Turbo Timers can usually be linked to the alarm so it can still be running and alarmed and then shut down. |
bredzy
Number of posts: 27 Home City: Roseau Model and year: 1997 Toyota Hiace Wagon
D-T G CABIN X Registration date: 2010-05-29
 | Subject: Re: Turbo Timer - Required? Sat Sep 11, 2010 1:01 pm | |
| Greetings. What is the recommended amount of time needed to cool down a 3.0L Diesel Turbo Toyota Hiace 1997 after a long and hard run? |
dandywarhol
Number of posts: 163 Age: 57 Home City: Edinburgh, Scotland Model and year: 1995 LH129V 2.8 Superlong semi hi top campervan 4WD with Mitsubishi turbo Registration date: 2010-01-26
 | Subject: Re: Turbo Timer - Required? Sun Sep 12, 2010 3:08 pm | |
| I fitted one to mine - its not to do with how hot it gets it's to allow the oil to circulate in the 1000,000+ rpm turbine. Its even more suitable to a non liquid cooled turbo
1 minute should be enough to allow the turbine to slow down before turning off |
Gonzo63
Number of posts: 4 Age: 48 Home City: Newcastle, NSW, Australia Model and year: 1995 Super Custom Limited
3.0L Turbo Diesel - Automatic - 4WD. Registration date: 2010-09-04
 | Subject: Re: Turbo Timer - Required? Sun Nov 14, 2010 7:00 am | |
| This will be one of the first items I fit to my 95 SCL. The main purpose for Turbo Timers is to allow the Turbo Charger to Spool Down before the Engine cuts off. This is so the Turbocharger can still get lubrication while it is spinning at very high speed to prevent premature failure. The other benefit of course is the time it allows to cool the Turbo down.
Cheers Geoff |
dandywarhol
 | Subject: Re: Turbo Timer - Required? Sun Nov 14, 2010 3:39 pm | |
| Much less of a problem with water cooled turbos - has the 3.0 turbo got coolant running round it? |
